Android remote app
theRCRH
Android remote app
Post by theRCRH »
Does the Kodi Core app work to control MRMC?
If not, is there an android remote for MRMC?
Thanks.
theRCRH
Re: Android remote app
Post by theRCRH »
nevermind.
I had the webserver in MRMC turned off.
I turned it on and kodi core works.
But I'm using the plex back end and the app doesn't show anything in my library.
I'm guessing that is because of plex but it is unfortunate.
