In Progress submenu item lists all shows
tretneo
Post by tretneo »
Hey MrMC team,
I see a lot of threads on TV "In Progress" issues, not sure if this one falls under one of the known cases. I am seeing all TV shows listed (some are fully watched, some are "in progress" and some I haven't started yet) when looking at the TV In Progress submenu view.
Details:
Apple TV 4
TvOS 10.0.1
Plex Server 1.2.6.2975
MrMC 2.7-1 Git:2016-11-04-abf4e4f-dirty
- tret
Re: In Progress submenu item lists all shows
hm, no idea why you have it like that.. that looks like MrMC database listing
here is what my "in Progress" looks like... displayed order is a bit different depending on how you have it setup on plex and on MrMC
tretneo
Post by tretneo »
Here's my On Deck
I am going to blow away MrMC on my Apple TV and start w/ a fresh install. This install (w/ Plex) was set up a few releases back sometime in September. I'll let you know the result.
Note: I switched to the Amber skin (like you are using) but see the same result.
tretneo
Post by tretneo »
Did a fresh install on Apple TV, went directly to settings and signed into my Plex account. No other settings applied, same issue occurs. How can I help debug this? Is there a method for pulling debug logs from MrMC on Apple TV?
tretneo
Post by tretneo »
Good stuff, thanks! Been a while since I looked at Kodi logging but it looks like it pulled all TV shows when calling the TV In Progress playlist.
10:14:11 T:6144962560  NOTICE: special://profile/ is mapped to: special://masterprofile/
10:14:11 T:6144962560  NOTICE: -----------------------------------------------------------------------
10:14:11 T:6144962560  NOTICE: Starting MrMC (2.7-1 Git:2016-11-04-abf4e4f-dirty). Platform: TVOS ARM64 64-bit
10:14:11 T:6144962560  NOTICE: Using Release MrMC x64 build
10:14:11 T:6144962560  NOTICE: MrMC compiled Nov  4 2016 by Clang 8.0.0 (clang-800.0.38) for TVOS ARM64 64-bit version 9.1.0 (90100)
10:14:11 T:6144962560  NOTICE: Running on Apple Inc. AppleTV5,3 with TVOS 10.0.1, kernel: Darwin ARM 64-bit version 16.1.0
10:14:11 T:6144962560  NOTICE: Host CPU: arm64 v8, 2 cores available
10:14:11 T:6144962560  NOTICE: ARM Features: Neon enabled
10:14:11 T:6144962560  NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/0F81E0BB-C6B2-47D1-86A9-1EB56AF19C32/MrMC.app/AppData/AppHome
10:14:11 T:6144962560  NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/0F81E0BB-C6B2-47D1-86A9-1EB56AF19C32/MrMC.app/AppData/AppHome
10:14:11 T:6144962560  NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/E1B95C26-5718-4D0C-86EF-A8E853874672/Library/Caches/home/userdata
10:14:11 T:6144962560  NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/E1B95C26-5718-4D0C-86EF-A8E853874672/Library/Caches/home
10:14:11 T:6144962560  NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/E1B95C26-5718-4D0C-86EF-A8E853874672/tmp/temp
10:14:11 T:6144962560  NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/E1B95C26-5718-4D0C-86EF-A8E853874672/Library/Caches/logs/
10:14:11 T:6144962560  NOTICE: special://frameworks/ is mapped to: /var/containers/Bundle/Application/0F81E0BB-C6B2-47D1-86A9-1EB56AF19C32/MrMC.app/Frameworks
10:14:11 T:6144962560  NOTICE: The executable running is: /var/containers/Bundle/Application/0F81E0BB-C6B2-47D1-86A9-1EB56AF19C32/MrMC.app/MrMC
10:14:11 T:6144962560  NOTICE: Local hostname: Office
10:14:11 T:6144962560  NOTICE: Log File is located: special://logs/mrmc.log
10:14:11 T:6144962560  NOTICE: load settings...
10:14:11 T:6144962560 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
10:14:11 T:6144962560 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
10:14:11 T:6144962560 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
10:14:11 T:6144962560   ERROR: CSetting: missing <control> tag of "videoscreen.vsync"
10:14:11 T:6144962560 WARNING: CSettingGroup: unable to read setting "videoscreen.vsync"
10:14:11 T:6144962560  NOTICE: Found 1 Lists of Devices
10:14:11 T:6144962560  NOTICE: Enumerated DARWINIOS devices:
10:14:11 T:6144962560  NOTICE:     Device 1
10:14:11 T:6144962560  NOTICE:         m_deviceName      : default
10:14:11 T:6144962560  NOTICE:         m_displayName     : Default
10:14:11 T:6144962560  NOTICE:         m_displayNameExtra:
10:14:11 T:6144962560  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
10:14:11 T:6144962560  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
10:14:11 T:6144962560  NOTICE:         m_sampleRates     : 44100,48000
10:14:11 T:6144962560  NOTICE:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
10:14:11 T:6144962560  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
10:14:11 T:6144962560  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:14:11 T:6144962560  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:14:11 T:6144962560  NOTICE: Default DVD Player: dvdplayer
10:14:11 T:6144962560  NOTICE: Default Video Player: dvdplayer
10:14:11 T:6144962560  NOTICE: Default Audio Player: paplayer
10:14:11 T:6144962560  NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:14:11 T:6144962560  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:14:11 T:6144962560  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:14:11 T:6144962560   ERROR: CMediaSourceSettings: error loading special://masterprofile/sources.xml: Line 0, Failed to open file
10:14:11 T:6144962560  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:14:11 T:6144962560  NOTICE: Loaded playercorefactory configuration
10:14:11 T:6144962560  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:14:11 T:6144962560  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:14:11 T:6146682880  NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
10:14:11 T:6146682880  NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
10:14:11 T:6146682880  NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
10:14:11 T:6146682880  NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.043167
10:14:11 T:6146682880  NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
10:14:11 T:6146682880  NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
10:14:11 T:6146682880  NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
10:14:11 T:6146682880  NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.000500
10:14:11 T:6146682880  NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
10:14:11 T:6146682880  NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
10:14:11 T:6146682880  NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 8
10:14:11 T:6144962560  NOTICE: Running database version Addons20
10:14:11 T:6144962560  NOTICE: Found possible resolution for display 0 with 1920 x 1080
10:14:11 T:6144962560  NOTICE: Checking resolution 16
10:14:11 T:6144962560  NOTICE: GL_VENDOR = Apple Inc.
10:14:11 T:6144962560  NOTICE: GL_RENDERER = Apple A8 GPU
10:14:11 T:6144962560  NOTICE: GL_VERSION = OpenGL ES 3.0 Apple A8 GPU - 95.16
10:14:11 T:6144962560  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
10:14:11 T:6144962560  NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
10:14:11 T:6144962560  NOTICE: Running database version ViewModes6
10:14:11 T:6144962560  NOTICE: Running database version Textures13
10:14:11 T:6144962560  NOTICE: Running database version MyMusic56
10:14:11 T:6144962560  NOTICE: Running database version MyVideos99
10:14:11 T:6144962560  NOTICE: Running database version TV29
10:14:11 T:6144962560  NOTICE: Running database version Epg11
10:14:12 T:6144962560 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:14:12 T:6144962560  NOTICE: ActiveAE DSP - starting
10:14:12 T:6144962560  NOTICE: initialize done
10:14:12 T:6144962560  NOTICE: Running the application...
10:14:12 T:6145536000  NOTICE: starting zeroconf publishing
10:14:12 T:6144962560  NOTICE: starting upnp client
10:14:12 T:6152417280  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
10:14:12 T:6152417280  NOTICE: UDP: Listening on port 9777
10:14:13 T:6148403200  NOTICE: CPlexServices: Server found via plex.tv Tretflix
10:14:26 T:6144962560  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
10:14:26 T:6144962560  NOTICE: Enabled debug logging due to GUI setting. Level 2.
10:14:28 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
10:14:28 T:6144962560   DEBUG: OnKey: left (0xf082) pressed, action is Left
10:14:32 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
10:14:32 T:6144962560   DEBUG: OnKey: backspace (0xf008) pressed, action is Back
10:14:32 T:6144962560   DEBUG: found key /userdata/profiles.xml
10:14:32 T:6144962560   DEBUG: Previous line repeats 1 times.
10:14:32 T:6144962560   DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
10:14:32 T:6144962560   DEBUG: found key /userdata/guisettings.xml
10:14:32 T:6144962560   DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 31543 to 6049
10:14:32 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
10:14:32 T:6144962560   DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
10:14:32 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
10:14:32 T:6144962560   DEBUG: ------ Window Init (Settings.xml) ------
10:14:33 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
10:14:33 T:6144962560   DEBUG: OnKey: backspace (0xf008) pressed, action is Back
10:14:33 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
10:14:33 T:6144962560   DEBUG: ------ Window Deinit (Settings.xml) ------
10:14:33 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
10:14:33 T:6144962560   DEBUG: ------ Window Init (Home.xml) ------
10:14:33 T:6150696960   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
10:14:33 T:6150696960   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
10:14:34 T:6147829760   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:14:34 T:6147829760   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:14:35 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
10:14:35 T:6144962560   DEBUG: OnKey: left (0xf082) pressed, action is Left
10:14:36 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
10:14:36 T:6144962560   DEBUG: OnKey: left (0xf082) pressed, action is Left
10:14:36 T:6150696960   DEBUG: CCurlFile::GetMimeType - https://HOSTNAME:32400/library/metadata/19318/thumb/1478455314|&X-Plex-Container-Size=10&X-Plex-Container-Start=0&X-Plex-Token=PLEXTOKEN -> image/jpeg
10:14:36 T:6150696960   DEBUG: CFileCache::Open - opening <library/metadata/19318/thumb/1478455314> using cache
10:14:36 T:6150696960   DEBUG: Caching image 'https://HOSTNAME:32400/library/metadata/19318/thumb/1478455314|&X-Plex-Container-Size=10&X-Plex-Container-Start=0&X-Plex-Token=PLEXTOKEN' to '3/38bf2ebf.jpg':
10:14:36 T:6150696960   DEBUG: cached image 'special://masterprofile/Thumbnails/3/38bf2ebf.jpg' size 400x225
10:14:38 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:14:38 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:14:38 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
10:14:38 T:6144962560   DEBUG: OnKey: right (0xf083) pressed, action is Right
10:14:39 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:14:39 T:6144962560   DEBUG: OnKey: return (0xf00d) pressed, action is Select
10:14:39 T:6144962560   DEBUG: Activating window ID: 10025
10:14:39 T:6144962560   DEBUG: ------ Window Deinit (Home.xml) ------
10:14:39 T:6144962560   DEBUG: ------ Window Init (MyVideoNav.xml) ------
10:14:39 T:6144962560    INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
10:14:39 T:6144962560   DEBUG: CPlexDirectory::GetDirectory
10:14:39 T:6144962560   DEBUG: CPlexDirectory::GetDirectory strURL = plex://tvshows/inprogressshows/
10:14:40 T:6144962560   DEBUG: CPlexDirectory::GetDirectory '/all' client(Tretflix), shows(29)
10:14:42 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
10:14:42 T:6144962560   DEBUG: OnKey: backspace (0xf008) pressed, action is Back
10:14:42 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
10:14:43 T:6144962560   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
10:14:43 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
10:14:43 T:6144962560   DEBUG: ------ Window Init (Home.xml) ------
10:14:43 T:6147829760   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
10:14:43 T:6147829760   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
10:14:43 T:6152990720   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:14:43 T:6152990720   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:14:44 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:14:44 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:14:45 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
10:14:45 T:6144962560   DEBUG: OnKey: left (0xf082) pressed, action is Left
10:14:46 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
10:14:46 T:6144962560   DEBUG: OnKey: right (0xf083) pressed, action is Right
10:14:47 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:14:47 T:6144962560   DEBUG: OnKey: return (0xf00d) pressed, action is Select
10:14:47 T:6144962560   DEBUG: Activating window ID: 10025
10:14:47 T:6144962560   DEBUG: ------ Window Deinit (Home.xml) ------
10:14:47 T:6144962560   DEBUG: ------ Window Init (MyVideoNav.xml) ------
10:14:47 T:6144962560   DEBUG: CPlexDirectory::GetDirectory
10:14:47 T:6144962560   DEBUG: CPlexDirectory::GetDirectory strURL = plex://tvshows/inprogressshows/
10:14:47 T:6144962560   DEBUG: CPlexDirectory::GetDirectory '/all' client(Tretflix), shows(29)
10:14:49 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
10:14:49 T:6144962560   DEBUG: OnKey: backspace (0xf008) pressed, action is Back
10:14:49 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
10:14:49 T:6144962560   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
10:14:49 T:6144962560   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
10:14:49 T:6144962560   DEBUG: ------ Window Init (Home.xml) ------
10:14:49 T:6147829760   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
10:14:49 T:6147829760   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
10:14:49 T:6150696960   DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
10:14:49 T:6150696960   DEBUG: CHomeShelfJob::UpdateTotal() - Finished
10:14:50 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
10:14:50 T:6144962560   DEBUG: OnKey: right (0xf083) pressed, action is Right
10:14:51 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:14:51 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:14:52 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
10:14:52 T:6144962560   DEBUG: OnKey: right (0xf083) pressed, action is Right
10:14:53 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
10:14:53 T:6144962560   DEBUG: OnKey: left (0xf082) pressed, action is Left
10:14:53 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0111, unicode: 0x0000, modifier: 0x0
10:14:53 T:6144962560   DEBUG: OnKey: up (0xf080) pressed, action is Up
10:14:54 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:14:54 T:6144962560   DEBUG: OnKey: return (0xf00d) pressed, action is Select
10:14:54 T:6144962560   DEBUG: Activating window ID: 10004
10:14:54 T:6144962560   DEBUG: ------ Window Deinit (Home.xml) ------
10:14:54 T:6144962560   DEBUG: ------ Window Init (Settings.xml) ------
10:14:58 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0111, unicode: 0x0000, modifier: 0x0
10:14:58 T:6144962560   DEBUG: OnKey: up (0xf080) pressed, action is Up
10:14:59 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:14:59 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:15:00 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:15:00 T:6144962560   DEBUG: OnKey: return (0xf00d) pressed, action is Select
10:15:00 T:6144962560   DEBUG: Activating window ID: 10016
10:15:00 T:6144962560   DEBUG: ------ Window Deinit (Settings.xml) ------
10:15:00 T:6144962560   DEBUG: ------ Window Init (SettingsCategory.xml) ------
10:15:02 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:15:02 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:15:03 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:15:03 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:15:04 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:15:04 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:15:04 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
10:15:04 T:6144962560   DEBUG: OnKey: right (0xf083) pressed, action is Right
10:15:05 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:15:05 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:15:06 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
10:15:06 T:6144962560   DEBUG: OnKey: down (0xf081) pressed, action is Down
10:15:07 T:6144962560   DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:15:07 T:6144962560   DEBUG: OnKey: return (0xf00d) pressed, action is Select
10:15:07 T:6144962560  NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:15:07 T:6144962560  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:15:19 T:6144962560  NOTICE: WebServer: Started the webserver
- tret
ok, found and fixed it... in for next version release
difference is that I had more than one TV Show section/server and there was an issue if there was only one(which is what you have).
thanks for reporting it!!
tretneo
Post by tretneo »
Excellent, thanks for getting that patched. Happy to help :)
