Internal Service Failure on startup
manumx
Post by manumx »
Just downloaded mrmc and when I try to start up I'm greeted with error.
Internal Service Error
An internal error occurred. This can be caused by lacl of network connecticity. Please make sure you have a good network connection.
Clicking OK shuts down the app.
I'm using 2nd generation Fire TV. Apps like Kodi/SPMC/Netflix work fine. Network is fine. I am located in Finland (if that's of any help).
Any tips?
Re: Internal Service Failure on startup
it might be impossible to get it, but debuglog is the only way to know
have you tried reinstalling it?
We do not have an error like that, anywhere in the app... its possible that FTV is throwing an error... picture maybe?
