Disable swipe up/down functionalities
y.belenky
Post by y.belenky »
How can I disable swipe up and down on my touch screen? When I watching live TV and trying to adjust brightness by bringing iOS build-in menu up, in most cases the application trying to switch channels.
Re: Disable swipe up/down functionalities
hi,
there is no way to disable swipe functions at the moment.
y.belenky
Post by y.belenky »
Thanks for prompt answer.
Any plans to fix this? Very annoying feature for so good application.
we can look into it, its not a bug though.... we intended it that way :)
y.belenky
Post by y.belenky »
Great, thanks! And I understand that it is not a bug, but on Apple devices it interfering with build-in gesture ...
