help,the error
never say
help,the error
Post by never say »
cd . && git log > /Users/apple/Desktop/mrmc-mrmc-release_2.5.0/tools/depends/target/libdvdcss/iphoneos9.2_arm64-target/ChangeLog-tmp
fatal: Not a git repository (or any of the parent directories): .git
make[4]: [ChangeLog] Error 128 (ignored)
test -s ChangeLog-tmp && mv ChangeLog-tmp ChangeLog
make[4]: *** [ChangeLog] Error 1
make[3]: *** [all] Error 2
make[2]: *** [iphoneos9.2_arm64-target/.libs/libdvdcss.a] Error 2
make[1]: *** [libdvdcss] Error 2
make: *** [target/.installed-iphoneos9.2_arm64-target] Error 2
what should i do, who can help me
Re: help,the error
look like depends was not setup correctly. make sure you follow the readme, we are slightly different than kodi.
never say
Re: help,the error
Post by never say »
davilla wrote:look like depends was not setup correctly. make sure you follow the readme, we are slightly different than kodi.
See docs/README.xxx for specific platform build information.
i sure follow this README.iOS
Re: help,the error
tools/depends/README
never say
Re: help,the error
Post by never say »
davilla wrote:tools/depends/README
i also see that ,but, useless
Re: help,the error
whats useless?
cd tools/depends
./bootstrap
./configure --host=arm-apple-darwin --with-cpu=arm64
make clean
make
I do it once a day and all is good...
never say
Re: help,the error
Post by never say »
amet wrote:whats useless?
cd tools/depends
./bootstrap
make clean
make
oh,make clean?!,i will do it
Re: help,the error
make clean is normal procedure if something fails, you need to clean it :)
you can also try to clean just the depend that failed.... in your case "libdvdcss"
make -C target/libdvdcss/ clean
and/or
make -C target/libdvdcss/ distclean
then run make and it will skip the ones that are finished and continue with the ones that are not
never say
Re: help,the error
Post by never say »
amet wrote:make clean is normal procedure if something fails, you need to clean it :)
and/or
checking for Java compiler... javac -target 1.1 -source 1.3
is this reason
never say
Re: help,the error
Post by never say »
Without a clue, I don't know where the problem is.
