is there a way to watch recorded tv shows with MrMc on iPAD? I cannot see any menu for this. On AppleTV everything is working fine, except the pause bug which will be fixed with version 2.5.
Thank you very much.
Frank.
Records?
Re: Records?
Recorded tv shows implies you are using some binary pvr. Is this what you mean ?
Re: Records?
oh, on ipad you have to change the skin to see TV stuff if I recall correctly.
Re: Records?
Its possible that we need to tweak touch skin to show recordings, I'll add it to a list of things to check and fix
fdzaebel
Re: Records?
Thank you very much for your fast replies.
To this means that currently in the iPad Version I cannot see records of live tv shows (e.g. made by NextPVR) but you plan to add this feature in the future?
Thanks,
Frank.
Thanks,
Frank.
Re: Records?
for now just change the skin to MrMC default. settings - appearancefdzaebel wrote:Thank you very much for your fast replies.
Thanks,
Frank.
