Connect to Sinology NAS
kendang
Post by kendang »
My Synology NAS is not found under Windows (SMB).
It is found under Zeroconfig. However, it does not allow me to connect using my credentials.
On my computer with Kodi installed, I can access to Windows smb shares on my Synology NAS.
Thanks.
Re: Connect to Sinology NAS
kendang
Post by kendang »
I could not find
Settings -> System -> Debugging
"enable web server" was DONE
Settings -> System -> Services -> Allow Remote control via HTTP
However, I'm still not able to find smb shares under Windows (smb). If I try to connect to my NAS listed under "zeroconfig", after enter my credentials, I get redirect to user/password prompts again.
kendang
Post by kendang »
Adding NAS IP address manually works. Browsing smb shares does not work.
