Unable to combine with plex
Ds24mr
Post by Ds24mr »
I have a problem with mrmc.
Today i bought it with my Firetv 1 Stick.
Installing works without issues, at the options i take my Login and Pin method.
And then nothing changes, i see a New categorie Filme and Serien, but without my stuff.
Did someone know where the (my) mistake is?
By the way i can only take 50 and 60 Hz no 24Hz, I read that all frequenzies are possible with mrmc. :?:
Re: Unable to combine with plex
All frequencies that the fireOS provides, yes. All frequencies that the display can do, no.
MrMC.log with debug enabled (see http://mrmc.tv/forum/viewtopic.php?f=12&t=373 ) , email to [email protected].
Ds24mr
Post by Ds24mr »
23:17:54 T:1107125552 DEBUG: CEGLNativeTypeAndroid:ProbeResolutions: 1280x720 @ 60.00 - Full Screen
23:17:54 T:1107125552 DEBUG: CEGLNativeTypeAndroid:ProbeResolutions: 1920x1080 @ 60.00 - Full Screen
23:17:54 T:1107125552 DEBUG: CEGLNativeTypeAndroid:ProbeResolutions: 1280x720 @ 50.00 - Full Screen
23:17:54 T:1107125552 DEBUG: CEGLNativeTypeAndroid:ProbeResolutions: 1920x1080 @ 50.00 - Full Screen
That's all it sees from FireOS.
Not seeing anything regarding plex client. You say "at the options i take my Login and Pin method." Pick one, user login OR Pin request. Like to see a log after you do this again.
Ds24mr
Post by Ds24mr »
Problem is solved. Ive installed it on my Firetv 1(not Stick) and it works fine.
Then i deinstall it on the Stick and install again and now it works. Now dts is not working. On both Sticks, kodi works fine width dts.
dts passthrough will return in the next version. for now, either transcode to ac3 or decode to pcm.
Ds24mr
Post by Ds24mr »
Thank you! :)
