how to edit advancedsettings.xml
sharky
Post by sharky »
Hello ,
while playback 1080p files every five to ten minutes the audio and video is out of sync. I think this is a result of bad wifi connection. Because I can't fix the wifi problem easily , I would like to cange the chache setting in mrmc. Normally I can ssh into my kodi host and edit the advancedsettings.xml, but how I am I'm doing this with mrmc ?
Re: how to edit advancedsettings.xml
Post by cosmoxl »
you can edit cache settings in MrMC GUI. You just might have to change the settings level from basic to advanced or expert.
settings ->system->internet access
sharky
Post by sharky »
Thanks , what is recommended buffer size on fire tv Stick ? Left it on default 20MB. turned on use smb v1 and buffering all filesystem.
sharky wrote:Thanks , what is recommended buffer size on fire tv Stick ? Left it on default 20MB. turned on use smb v1 and buffering all filesystem.
fire tv Sticks have very little ram, something to keep in mind.
