Hello. I have been using MrMC on Apple TV 4 for a while and decided to buy the IOS version today.
However I am experiencing the same problem that this guy had:
""Hello,
First of all, thanks for this great IOS release, i have always been a huge fan of XBMC/KODI/MRMC.
I don't know if this may be a bug, but i'm using tvheadend server and the "tvheadend HTSP client" from the plugin menu.
On my ATV4 (TVOS release) everything is working like a charm, but on my iPad air2 / iPhone 6s i can't get this plugin to work.
I can do the server, username and password setup from the "tvheadend HTSP client" and enable.
And from the TV settings menu i can enable the PVR, and i can see in the top that the channels are loaded, but i can't get the TV menu/icon visible on the "frontpage" so i can't open the TV "app".
I don't know if i may have missed something in the setup?""
But I am unable to activate TV in Skin settings. There is no such option there.
Cannot activate TV and therefore not access IPTV plugin.
I saw that the version of MrMC Touch I bought got released 17/5 maybe something broken in this version?
Thankful for help regarding this.
/ Roger.
TV Does not show up on home screen.
Re: TV Does not show up on home screen.
Activating Pvr addons and enabling tv in settings will enable "live tv" on home
Roger_K
Found the problem.
It was my network link to playlist in my google drive that made it all a mess.
Made a local file now and all is well.
Thank you for your reply.
