Gday There,
Ive had MRMC installed on our AppleTV for over a year now without issue. (Using AMber Skin , not sure if this matters)
The last 4 or 5 movies are all showing up with no posters or fanarts , and when i manually try to find a post or fanart - only a single crappy thumbnail in stretched res shows up.
Can anyone point me the direction of the add-on responsible for fanart and posters ? Im hoping i can just roll back a update or reset it.
cheers.
Since 1st July - No Posters or Fanart is found
Re: Since 1st July - No Posters or Fanart is found
There is no addon to roll back, possibly there might be an issue with the scrapers.
I’ll have a look
I’ll have a look
wobaby
Cheers mate.
Your quick reply is much appreciated.
Also, is there a log file in appletv I can paste into here ?
Mark.
Mark.
Yes, follow the debuglog instructions
wobaby
scrapers updated, Settings -> Extensions -> Hidden menu on the left -> Check for Update , its should also update in few hours if you let it run on Auto
edit: Ariana and Opacity skin
wobaby
Cheers Amet.
Much appreciated.
Much appreciated.
