Hi guys, i cannot upload my videos thourgh mrmc.
I have a synology nas, and i have enabled use libdsm for smb servers.
Now when i search it it finds my nas but then i get the error code 6 and sometimes error code 2 , any idea what the problem is ?
The nas works perfectly with the app infuse. But im more keen on using it with mrmc.
my debug log is: VSF46.log
can not upload video synology nas to mrmc
- Waltman
Re: can not upload video synology nas to mrmc
Are you in the latest TestFlight ? Several issues with smb and nfs are resolved in the latest testbuild.
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Why libdsm? What do you get when using a libsmb2 or If you deselect both?
- logan_x50
why do you want to use smb?
NFS in my experience much quicker and works flawlessly with mrmc
https://www.synology.com/en-global/know ... etwork_NFS
Premux
when i try libsmb2 i cant find the nas server, it doesn show up.
As the same for NFS also it does not show up. I must be doing something wrong.
Did anyone check the debuglog ? could you anything wrong ?
Below is the part of log showing your connection fails
I am not sure why you are using libdsm, deselect it and deselect smb2 and see what you get.
00:41:29.495 T:6094647296 DEBUG: CDSMSession: Failed to connect using SMB_TRANSPORT_TCP, trying SMB_TRANSPORT_NBT
00:41:29.526 T:6094647296 ERROR: CDSMSession: Failed to connect-
Premux
so i did a little research and i did as logan_x50 said and NFS is working like charm. Just some setting that you have deal with and the rest is ok.
thx everyone
thx everyone
