Select audio track
whatisk
Select audio track
Post by whatisk »
Just wondering if there is a way to select the audio track to play on a file that has multiple? Some files I have have a commentary track (for example) so was wondering if there is a way to switch tracks once playing.
I did also have a question about selecting subtitles, but found the wiki page where it mentions a triple tap to toggle subtitles. I'm yet to test as I use a Harmony remote rather than the Apple one, but will hopefully be able to get it simulated. I'm assuming the triple tap toggles through the available subtitles, or does it just toggle on/off. Though I will test myself :)
EDIT: looks as though the Harmony doesn't emulate/send the taps, just actual keys/presses.
Re: Select audio track
While watching a video, swipe down and you have a subtitle and audio menu… choose your subs or audio track there
whatisk
Post by whatisk »
Awesome. Thank you. I have found I can access it using the Harmony by pausing and then pressing down.
I should have read the wiki more closely.
mrmc3qpe
Post by mrmc3qpe »
Hello,
that doesn't seem to be working on the Apple TV 4K 2021 Siri Remote. Swiping up or down changes the channel while watching TV using pvr.hts plugin for TvHeadend.
mrmc3qpe wrote: 26 May 2021, 10:38 Hello,
Of course it works, just doesn’t work on live tv… on live tv you need to click Siri pad to bring out the OSD and it would be on top
mrmc3qpe
Post by mrmc3qpe »
amet wrote: 26 May 2021, 12:14
Your hint helped me, I had changed the skin. The menu to change the audio track seems to be displayed only using the skin "Ariana".
Thx again,
John
