Hi All,
Just done a fresh install of latest MRMC 3.9.10 for Apple TV and using the plex (core) service. The sort options for TV show seasons and episodes do not appear to be applying globally. On previous versions I would just go into the first TV show, change the season / episode view and it would apply to all other shows by default. I've tried all other skins and the results are the same.
TV Season / Episode view mode not applied globally
DC1983
Re: TV Season / Episode view mode not applied globally
Is there any news on this or is anyone seeing the same thing?
I don't see it on my limited testing, I don't use the Plex server as main server... maybe someone else can confirm
DC1983
Thanks amet,
appreciate the help and sorry to chase, I know you guys are very busy.
I installed the lite version which is at version 3.9.7 as a test and same results there, also the same issue observed on the android tablet version so perhaps something on the Plex side. the plex addon method works but I'm not sure this really helps as i think the views are forced within the addon.
Would a log help? I could add you to the plex server if needed.
generally, each page has its own view preference... I think(I would have to check) that default is list view, once you change that the path of the window and view gets saved.
Its not Plex issue, if it is an issue, but its the way core handles windows... I'll check more here
DC1983
Thanks amet,
Did you find anything? As you say the views for show and season work fine with local paths just not with Plex.
not much, busy with other things. I did look into it and I can see what you are seeing... I'll try to find some time to do it.
DC1983
Thanks amet,
Appreciate it.
Appreciate it.
don't be shy to kick me in a head to remind me
DC1983
Haha no worries,
Likewise if you need to tell me to sod off I won't be offended
