Hi
Just purchaced an ATV4 and installed MrMC on it. Everything works fine, accept the sound.
I have a 7.1 cappable reciever, running the ATV4 via HDMI directly to the reciever.
But when the movie is i dolby DTS, the sound that is supposed to come out of the center speaker, is comming out of the rear surround speaker.. You know when people speaks ect. That is realy realy annoying. I have tried setting it to 5.1, same thing. When i set it to 2.0, the sound comes out correctly from the center speaker, but then it is only on stereo (obviosly)
All other sounds on the appleTV is OK. Altså movies from the app store plays on the ATV is as it is supposed to. I changed my ATV2 out, to this ATV4, and there was no problem on the ATV2 either (With kodi)
Any ideas?
Surround Center-sound out of wrong speaker
Re: Surround Center-sound out of wrong speaker
humm, that's two reports of this now.
- timstephens24
Same issue for me. I ran my DTS-HD MA 5.1 sound test file and here's how they're mapped:
DTS-HD MA 5.1 (passthrough enabled - passed as DTS)
Front Left --> Front Left
Center --> Center
Front Right --> Front Right
Right Surround --> Right Surround
Left Surround --> Left Surround
LFE --> LFE
DTS-HD MA 5.1 (passthrough disabled -- passed as PCM)
Center --> Right Surround
Right Surround --> Center
Left Surround --> LFE
LFE --> Left Surround
Edit: Fixed center mapping
Center --> Center
LFE --> LFE
Fero1233
Tried running Plex instead. Sound is great, and as it supossed to.
So it is only when using MrMC and DTS.
But i would like to use MrMC (as i also pay'd for it), so if anyone have a fix for it - let me know.
onlyzuul
I've got this problem as well. DTS and Dolby Digital audio via pass through works great but with PCM I'm getting center sound out of right rear. I have a bunch of video files with 5.1 AAC audio that get messed up when played with mrmc. Infuse plays these just fine.
We have identified the issue and fix is being applied.
Update coming soon.
Update coming soon.
Fero1233
Sounds good, let me know when it's fixed. Thx
It's fixed, it will be in a next version
Fero1233
Does it update automaticly, or when/how do i update it??
If you have autoupdate set in tvOS, it will autoupdate.Fero1233 wrote:Does it update automaticly, or when/how do i update it??
We will be pushing v2.2 up soon, then it takes 3-4 days for Apple approval.
