TV Recordings empty after sleep ATV4 / TVH
Carsten
Post by Carsten »
Hello,
I am using latest mrmrc on ATV4 with latest TV-Headend as backend.
Every now and then, the recordings will completely disappear. They will come back when I restart mrmrc. By this I mean: I wake up my ATV, I klick on mrmc (which will normally be open in the background from last time of usage). I klick on TV, I klick left to show selection menu, I klick on Recordings. Normally, the list of Folders will appear on the right. When it is buggy, to will only show ".." on the right. No chance to select anything, go back in directory hierarchy etc.
I can work around by killing the mrmrc app manually and restart. Then it will connect to TVH and reload channel information and recordings. Everything will be back to normal.
It is not a big issue, but can you imagine to fix it? I think some initialisation routine that is called on app startup also needs to be called when the ATV4 or mrmc app is waking up (or whatever this is called in tvOS).
Thanks,
Carsten.
