- Regularly when displaying the guide, an earlier "current time" is displayed. For example if I earlier opened the guide at 8am and then opened it again at 8pm the guide for 8am is still displayed until I exit the guide and opened it again. This seems to refresh and show the guide at the correct current time.
- Sometime channels do not start. In this log I made a couple of attempts to select a channel from the guide but they both failed and returned to the guide without starting playing the channel. I quit/closed the MrMC application entirely in AppleTV and then reloaded it and the channel immediately loaded fine from the guide.
18:41:19.974 T:6172831744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to write (Invalid argument)
18:41:19.998 T:6172831744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to transmit
18:41:19.998 T:6172831744 ERROR: PVR - GetEPGForChannel - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: server error
18:41:19.998 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'Seven 2' from client '1': server error
18:41:19.998 T:6172831744 ERROR: EPG - Update - failed to update table 'Seven 2'
18:41:19.999 T:6172831744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to write (Invalid argument)
18:41:19.999 T:6172831744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to transmit
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: server error
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'ABC 1' from client '1': server error
18:41:19.999 T:6172831744 ERROR: EPG - Update - failed to update table 'ABC 1'
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'Ten' from client '1': server error
18:41:19.999 T:6172831744 ERROR: EPG - Update - failed to update table 'Ten'
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'Nine' from client '1': server error
18:41:19.999 T:6172831744 ERROR: EPG - Update - failed to update table 'Nine'
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'ABC News' from client '1': server error
18:41:19.999 T:6172831744 ERROR: EPG - Update - failed to update table 'ABC News'
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'Seven 1' from client '1': server error
18:41:19.999 T:6172831744 ERROR: EPG - Update - failed to update table 'Seven 1'
18:41:19.999 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'SBS' from client '1': server error
18:41:19.999 T:6172831744 ERROR: EPG - Update - failed to update table 'SBS'
18:41:20.000 T:6172831744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to transmit
18:41:20.000 T:6172831744 ERROR: PVR - GetEPGForChannel - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: server error
18:41:20.000 T:6172831744 ERROR: PVR - GetEPGForChannel - cannot get EPG for channel 'ABC 2' from client '1': server error
18:41:20.000 T:6172831744 ERROR: EPG - Update - failed to update table 'ABC 2'
18:41:20.008 T:6158495744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to write (Invalid argument)
18:41:20.008 T:6158495744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to transmit
18:41:20.008 T:6158495744 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to send hello
18:41:20.144 T:6162509824 NOTICE: Found 1 Lists of Devices
18:41:20.144 T:6162509824 NOTICE: Enumerated DARWINIOS devices:
18:41:20.144 T:6162509824 NOTICE: Device 1
18:41:20.144 T:6162509824 NOTICE: m_deviceName : default
18:41:20.144 T:6162509824 NOTICE: m_displayName : Default
18:41:20.144 T:6162509824 NOTICE: m_displayNameExtra:
18:41:20.144 T:6162509824 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:41:20.144 T:6162509824 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
18:41:20.144 T:6162509824 NOTICE: m_sampleRates : 44100,48000
18:41:20.144 T:6162509824 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT
18:41:20.144 T:6162509824 NOTICE: m_streamTypes : No passthrough capabilities
18:41:20.159 T:6163083264 NOTICE: getNativeAudioSettings:Stereo
18:41:20.162 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting channels 2
18:41:20.163 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting samplerate 48000.000000
18:41:20.163 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting buffer duration to 0.042667
18:41:20.183 T:6163083264 NOTICE: dumpAVAudioSessionProperties:maxchannels 2, deactivateMaxchannels 2
18:41:20.192 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:total latency = 0.176812
18:41:20.192 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
18:41:20.192 T:6163083264 NOTICE: dumpAVAudioSessionProperties:audio route = HDMIOutput
18:41:20.192 T:6163083264 NOTICE: dumpAVAudioSessionProperties:sampleRate 48000.000000
18:41:20.192 T:6163083264 NOTICE: dumpAVAudioSessionProperties:outputLatency 0.091479
18:41:20.192 T:6163083264 NOTICE: dumpAVAudioSessionProperties:IOBufferDuration 0.042667
18:41:20.192 T:6163083264 NOTICE: dumpAVAudioSessionProperties:outputNumberOfChannels 2
18:41:20.192 T:6163083264 NOTICE: dumpAVAudioSessionProperties:maximumOutputNumberOfChannels 2
18:41:20.193 T:6163083264 NOTICE: dumpAVAudioSessionProperties:SessionPortOutputNumberOfChannels 2
18:41:20.193 T:6163083264 NOTICE: CAESinkDARWINIOS::Initialize: channel_index 0, maxChannels 2, outputChannels 2, portChannelCount 2
18:41:20.298 T:6162509824 NOTICE: Found 1 Lists of Devices
18:41:20.298 T:6162509824 NOTICE: Enumerated DARWINIOS devices:
18:41:20.298 T:6162509824 NOTICE: Device 1
18:41:20.298 T:6162509824 NOTICE: m_deviceName : default
18:41:20.298 T:6162509824 NOTICE: m_displayName : Default
18:41:20.298 T:6162509824 NOTICE: m_displayNameExtra:
18:41:20.298 T:6162509824 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:41:20.298 T:6162509824 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
18:41:20.298 T:6162509824 NOTICE: m_sampleRates : 44100,48000
18:41:20.298 T:6162509824 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT
18:41:20.298 T:6162509824 NOTICE: m_streamTypes : No passthrough capabilities
18:41:20.301 T:6163083264 NOTICE: getNativeAudioSettings:Stereo
18:41:20.303 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting channels 2
18:41:20.303 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting samplerate 48000.000000
18:41:20.303 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting buffer duration to 0.042667
18:41:20.323 T:6163083264 NOTICE: dumpAVAudioSessionProperties:maxchannels 2, deactivateMaxchannels 2
18:41:20.333 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:total latency = 0.176812
18:41:20.334 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
18:41:20.334 T:6163083264 NOTICE: dumpAVAudioSessionProperties:audio route = HDMIOutput
18:41:20.334 T:6163083264 NOTICE: dumpAVAudioSessionProperties:sampleRate 48000.000000
18:41:20.334 T:6163083264 NOTICE: dumpAVAudioSessionProperties:outputLatency 0.091479
18:41:20.334 T:6163083264 NOTICE: dumpAVAudioSessionProperties:IOBufferDuration 0.042667
18:41:20.334 T:6163083264 NOTICE: dumpAVAudioSessionProperties:outputNumberOfChannels 2
18:41:20.334 T:6163083264 NOTICE: dumpAVAudioSessionProperties:maximumOutputNumberOfChannels 2
18:41:20.335 T:6163083264 NOTICE: dumpAVAudioSessionProperties:SessionPortOutputNumberOfChannels 2
18:41:20.335 T:6163083264 NOTICE: CAESinkDARWINIOS::Initialize: channel_index 0, maxChannels 2, outputChannels 2, portChannelCount 2
18:41:20.433 T:6162509824 NOTICE: Found 1 Lists of Devices
18:41:20.433 T:6162509824 NOTICE: Enumerated DARWINIOS devices:
18:41:20.433 T:6162509824 NOTICE: Device 1
18:41:20.433 T:6162509824 NOTICE: m_deviceName : default
18:41:20.433 T:6162509824 NOTICE: m_displayName : Default
18:41:20.433 T:6162509824 NOTICE: m_displayNameExtra:
18:41:20.433 T:6162509824 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:41:20.433 T:6162509824 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
18:41:20.433 T:6162509824 NOTICE: m_sampleRates : 44100,48000
18:41:20.433 T:6162509824 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT
18:41:20.433 T:6162509824 NOTICE: m_streamTypes : No passthrough capabilities
18:41:20.439 T:6163083264 NOTICE: getNativeAudioSettings:Stereo
18:41:20.441 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting channels 2
18:41:20.441 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting samplerate 48000.000000
18:41:20.441 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setting buffer duration to 0.042667
18:41:20.463 T:6163083264 NOTICE: dumpAVAudioSessionProperties:maxchannels 2, deactivateMaxchannels 2
18:41:20.472 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:total latency = 0.176812
18:41:20.472 T:6163083264 NOTICE: CAAudioUnitSink::setupAudio:setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:audio route = HDMIOutput
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:sampleRate 48000.000000
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:outputLatency 0.091479
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:IOBufferDuration 0.042667
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:outputNumberOfChannels 2
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:maximumOutputNumberOfChannels 2
18:41:20.473 T:6163083264 NOTICE: dumpAVAudioSessionProperties:SessionPortOutputNumberOfChannels 2
18:41:20.474 T:6163083264 NOTICE: CAESinkDARWINIOS::Initialize: channel_index 0, maxChannels 2, outputChannels 2, portChannelCount 2
18:41:20.517 T:6162509824 WARNING: CActiveAE - received 3 device change events within one second
18:41:21.881 T:4369457216 WARNING: Previous line repeats 6 times.
18:41:21.882 T:4369457216 NOTICE: starting zeroconf publishing
18:41:21.883 T:4369457216 NOTICE: WebServer: Started the webserver
18:41:21.885 T:4369457216 NOTICE: starting upnp client
18:41:21.892 T:6183153664 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
18:41:21.893 T:6183153664 NOTICE: UDP: Listening on port 9777
18:41:21.930 T:6161936384 NOTICE: CDVDPlayer::Opening: pvr://channels/tv/All channels/pvr.hts_639350928.pvr
18:41:21.930 T:6161936384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:41:21.931 T:6188314624 NOTICE: Creating InputStream
18:41:24.888 T:6164803584 ERROR: PVR - GetChannelGroups - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: the command failed
18:41:24.888 T:6164803584 ERROR: PVR - GetChannelGroups - cannot get groups from client '1': the command failed
18:41:27.893 T:6164803584 ERROR: PVR - GetChannels - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: the command failed
18:41:27.893 T:6164803584 ERROR: PVR - GetChannels - cannot get channels from client '1': the command failed
18:41:30.894 T:6164803584 ERROR: PVR - GetChannels - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: the command failed
18:41:30.894 T:6164803584 ERROR: PVR - GetChannels - cannot get channels from client '1': the command failed
18:41:31.937 T:6188314624 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/pvr.hts_639350928.pvr]
18:41:31.937 T:6188314624 NOTICE: CDVDPlayer::OnExit()
18:41:31.961 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:41:31.961 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:41:31.961 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:41:31.963 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:41:31.963 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:41:31.963 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:41:33.900 T:6164803584 ERROR: PVR - GetRecordings - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: the command failed
18:41:33.900 T:6164803584 ERROR: PVR - GetRecordings - cannot get recordings from client '1': the command failed
18:41:35.835 T:6161936384 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'icons/pvr/HasTimerSchedule.png'
18:41:36.906 T:6164803584 ERROR: PVR - GetTimers - addon 'Tvheadend:192.168.188.12:9982 [connected]' returned an error: the command failed
18:41:36.906 T:6164803584 ERROR: PVR - GetTimers - cannot get timers from client '1': the command failed
18:41:59.009 T:6161936384 NOTICE: CDVDPlayer::Opening: pvr://channels/tv/All channels/pvr.hts_1544087472.pvr
18:41:59.010 T:6161936384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:41:59.011 T:6164230144 NOTICE: Creating InputStream
18:42:09.018 T:6164230144 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/pvr.hts_1544087472.pvr]
18:42:09.018 T:6164230144 NOTICE: CDVDPlayer::OnExit()
18:42:09.041 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:42:09.041 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:42:09.042 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:42:09.043 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:42:09.043 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:42:09.043 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:42:17.336 T:6161936384 NOTICE: CDVDPlayer::Opening: pvr://channels/tv/All channels/pvr.hts_1544087472.pvr
18:42:17.336 T:6161936384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:42:17.338 T:6160216064 NOTICE: Creating InputStream
18:42:27.348 T:6160216064 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/pvr.hts_1544087472.pvr]
18:42:27.349 T:6160216064 NOTICE: CDVDPlayer::OnExit()
18:42:27.381 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:42:27.382 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:42:27.382 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:42:27.383 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:42:27.383 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:42:27.383 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:42:36.452 T:6161936384 NOTICE: CDVDPlayer::Opening: pvr://channels/tv/All channels/pvr.hts_554933272.pvr
18:42:36.452 T:6161936384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:42:36.453 T:6160216064 NOTICE: Creating InputStream
18:42:46.464 T:6160216064 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/pvr.hts_554933272.pvr]
18:42:46.464 T:6160216064 NOTICE: CDVDPlayer::OnExit()
18:42:46.501 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:42:46.502 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:42:46.502 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:42:46.503 T:6161936384 NOTICE: CDVDPlayer::CloseFile()
18:42:46.503 T:6161936384 NOTICE: DVDPlayer: waiting for threads to exit
18:42:46.503 T:6161936384 NOTICE: DVDPlayer: finished waiting
18:42:49.245 T:6160216064 NOTICE: ES: Stopping event server
18:42:49.245 T:6160216064 NOTICE: stopping upnp
18:42:49.262 T:6161936384 NOTICE: Storing total System Uptime
