I'm on tvOS but I'm sure this is a generic issue, not specific to ATV/ATV4K.
Settings > Extensions > Extensions > Information Providers > Album information
Here there is a 'Local information only' add-on that is enabled.
In all the other categories, this add-on is not even listed.
1. None of the info provider add-ons are able to be disabled. I see viewtopic.php?f=27&t=5223&p=26843&hilit=disable#p26843 that maybe this is a new bug or new intentional behavior? So my first question, how to disable an info provider add-on?
2. How to get local info (.nfo) for the other categories?
3. Is embedded metadata (https://kodi.wiki/view/Video_file_taggi ... ag_options) supported by mrmc? Given I can't disable the other info providers, will info from those sources augment or replace any embedded metadata?
I would test this, however I worry that I in the initial step of testing I will pollute the metadata cache and then my test results will be inconclusive. On the tvOS version, there does not seem to be a control/setting to purge the local metadata cache (eg infuse has this as a button).
thanks all
