Hi everyone and thanks in advance for any help that can given on this.
I've hunted all over the net on a way to solve this issue but nothing is working for me, so I figured I'd give a shot with the experts.
I have a mac mini running high sierra as a media server in our home and have finally decided to use MRMC properly by setting up mysql and running a DB from there to keep the multiple apple tv's we have in sync.
I've installed mysql no issue but when I go to run the first command:
sudo /usr/local/mysql/bin/mysql
It asks for a password.
I initially assumed it was for the mysql install that just completed but that does not work.
I then thought well maybe it is the admin password for the mac machine. So I put that in and when I do that I get:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
I've tried to run commands to reset passwords on mysql and all the "google tips" I could find but nothing would work.
Has anyone experienced this on their installs?
And if so, how did you work around it.
Thanks again.
Brett
unable to get past: sudo /usr/local/mysql/bin/mysql
bmiddaugh
Re: unable to get past: sudo /usr/local/mysql/bin/mysql
It’s your sudo password, password for the user that’s logged in currently
And then you need the below command to specify the user
$mysql -u root -p
$mysql -u root -p
bmiddaugh
when i use that it gives me this error:
bmiddaugh
bmiddaugh
I am also using mysql 8.0.19 on high sierra.
bmiddaugh
every command I try gives me: ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
I'm not familiar with using mysql, but I figured I'd give this a shot.
Everything else works out well, probably have to pass on this capability.
(using password: NO) Means just that, did you use the command I pasted?
bmiddaugh
Hi Amet,
Thanks for sticking with me on this, I don't want to bog you down with it.
These are the exact commands I am trying and the results I am getting
Cottages-Mac-mini:~ cottageconundrumserver$ sudo /usr/local/mysql/bin/mysql
Password:
Cottages-Mac-mini:~ cottageconundrumserver$ mysql -u root -p
-bash: mysql: command not found
Cottages-Mac-mini:~ cottageconundrumserver$ sudo /usr/local/mysql/bin/mysql -u root -p
Enter password:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
