Hi, since the last update the Music Section ist no longer in the main menu. Even in the settings there ist no possibility to activate this section like videos, pictures, TV etc. .
Ist this a bug or didn't i find the correct settings? I'm using KODI since version 8, so i know the settings of the system.
Music section is missing in main menu
Re: Music section is missing in main menu
Which version please.Gunjahx wrote: 23 Apr 2019, 17:46 Hi, since the last update the Music Section ist no longer in the main menu. Even in the settings there ist no possibility to activate this section like videos, pictures, TV etc. .
Gunjahx
Latest version on Apple TV 4
"Latest version" really gives us no information
Gunjahx
Latest available version on the AppleStore should be clear, or not?
MrMC (3.8-1 Git:2019-04-16-60d492d-dirty). Platform: TVOS ARM64 64-bit
AppleTV5,3 with TVOS 12.1.2
Debug Log:
https://pastebin.com/HGpEsTuZ
Debug Log:
Might depend if we just pushed a version out (which we did), or if Apple stages the releases (which they do). Or if you have updates turned off. This is why we ask for the version...Gunjahx wrote: 25 Apr 2019, 16:21 Latest available version on the AppleStore should be clear, or not?
I don't understand why it's so hard to just report the version or debuglog.
We've asked several times now. Help us, help you.
Gunjahx
I've got two Apple TVs of the same type, both have exact the same issue.
Gunjahx
Does no one have any idea?
Amber skin? do you have the same issue on Opacity or Ariana?
looks like your Textures database is corrupt... full reinstall might help, but remember that you will loose your library setup.
18:31:40.863 T:6171111424 ERROR: Connect failed with 'SQL: [Textures13.db] The database disk image is malformed
