Deleted File not staying Deleted  [SOLVED]
PetSue
Post by PetSue »
I'm sorry if this has been asked but I couldn't find anything recent on it.
Everything is working fine all except when deleting files. I have the option in Settings to allow deletion and I can delete a file no problems, but then if MrMc re-scans the files just come back. So basically they are not being deleted from my NAS.
Have I missed a setting that I need to check or is there an issue?
Thank you :)
Re: Deleted File not staying Deleted
Post by koying »
A debuglog of a session where you try to delete a file might give us some hints
PetSue
Post by PetSue »
koying wrote: 22 Mar 2019, 05:45 A debuglog of a session where you try to delete a file might give us some hints
Apologies, here you go and thank you - https://pastebin.com/xESPptKJ
Post by koying »
Did you try to delete a file in this log? I can't seem to find where...
PetSue
Post by PetSue »
koying wrote: 25 Mar 2019, 07:47 Did you try to delete a file in this log? I can't seem to find where...
I deleted 2 files, restarted and they both came back.
File were Wicked Tuna episodes.
if you restarted it we would need debuglog old to see the delete session
chances are that NFS user needs more permissions to delete the files
PetSue
Post by PetSue »
amet wrote: 25 Mar 2019, 08:13 if you restarted it we would need debuglog old to see the delete session
Ok apologies, have deleted files again and not restarted which is this log - https://pastebin.com/Cpr1uBAU
This is Log Old - https://pastebin.com/4mpjWsJG
Thank you :)
Post by koying »
The delete failed, obviously:
19:39:39.410 T:6128873472 ERROR: Delete - Error( unlink call failed with "NFS: REMOVE of /Wicked Tuna/Season 8/Wicked Tuna - S08E02 - Game of Fins WEBDL-720p.mkv failed with NFS3ERR_ROFS(-30)" )
The error (NFS3ERR_ROFS) seems to point to a read-only filesystem, or not enough rights, I guess. see https://tools.ietf.org/html/rfc1813.
19:39:29.651 T:6128873472   ERROR: Delete - Error( unlink call failed with "NFS: REMOVE of /Wicked Tuna/Season 8/wicked.tuna.s08e01.battle.cry.1080p.web.h264-tbs.mkv failed with NFS3ERR_ROFS(-30)" )
19:39:29.651 T:6128873472   ERROR: Delete - Error deleting file nfs://192.168.1.105/TV Shows/Wicked Tuna/Season 8/wicked.tuna.s08e01.battle.cry.1080p.web.h264-tbs.mkv
its some NFS permission issue, "unlink call failed with "NFS: REMOVE"
PetSue
Post by PetSue »
amet wrote: 25 Mar 2019, 09:03
Yea I see what you mean, I just can't work out how to fix it gggrrr
