Control Buttons in DVD/Bluray menu - 3.8
bigpen23
Post by bigpen23 »
3.8.0 includes Blu-ray menu support which is excellent! When I use apple tv remote (not Siri remote, I like real buttons) to navigate the menu, every time I press the directional keys, it will jump "two times". I have tried both DVD menu and Bluray menu, it has the same problem. Is there a way to workaround it? or I have to wait for future update. Thanks.
Re: Control Buttons in DVD/Bluray menu - 3.8
If you are using the silver Apple remote , try enabling Siri expert mode in settings > system > input and see if that fixes the issue
Antibus
Post by Antibus »
I've had this same problem when navigating DVD menus with my ATV4 "Learned Remote". This problem goes back to the last few versions - I seem to remember it being a problem since at least last summer. Before that, the same configuration (a learned remote) worked fine. Everything else with this remote also currently works fine everywhere else - just a problem with DVD menus.
I’ll check, thanks
Can't reproduce. DVD with menus work fine here with appletv silver remote. One click gives one jump.
Need to see debuglog, that might help.
Antibus
Post by Antibus »
Here you go:
https://pastebin.com/0hCz5dz8
I simply played the dvd image and then tried moving down and up a few times using an old white Apple remote. Each time I tried to movie up or down, it would skip one menu item and go onto the next one.
BTW, as you may notice, this is a GitHub build of 3.7.1 running from Xcode. If you can give me some hints as to where in the code to look, I can try debugging it here.
found and fixed.
Antibus
Post by Antibus »
Awesome! :D
