Media Source - PVR IPTV Simple Client - Channel/Groups "partial load"
mge671
Post by mge671 »
Hello,
I just installed the MrMC app on my Shield android device and configured the PVR Simple Client for the M3u playlist and EPG. Only a partial list of Channel Groups (12) and Channels (511) were downloaded (Hidden=0). The channels and EPG that were downloaded appear to have loaded successfully and the channels can be played. I cannot determine why the remaining Channel Groups and Channels did not download.
I restarted the MrMC app several times and the same quantity loads each time.
I cleared the MrMC cache via the Shield's device Settings.
From MrMC TV-Settings I did a "Clear data".
It continues to say 511 channels. Any suggestions to be able to download the remaining Channel Groups and Channels?
Thanks!
Ted377
Re: Media Source - PVR IPTV Simple Client - Channel/Groups "partial load"
Post by Ted377 »
Sounds like a m3u list from the internet for me. Does this come from a "trustworthy" source?
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
