Not tried .mkv or .flac yet.
FireTV from QNAP NAS
Re: FireTV from QNAP NAS
Jpeg needs to be viewed from picture sources, how are you viewing it?
Stephen H
I was just on the Fire TV using MrMc.amet wrote: 14 Dec 2018, 07:45 Jpeg needs to be viewed from picture sources, how are you viewing it?
I downloaded MrMc last night to try to view my pictures on my QNAP 251A.
I'm hoping I can make is a little more user-friendly than using my WD live hub. The Mrs find it over complicated.
I'm hoping to also use it for .mkv's at a later date.
thanks
Go to media sources, pictures and add your source. That should add pictures tab in your home screen
Stephen H
I hit the solved by mistake!amet wrote: 14 Dec 2018, 19:12 Go to media sources, pictures and add your source. That should add pictures tab in your home screen
Can it be reversed?
I’ll have a go over the weekend.
