I just bought a FTV Stick 4K and when I play a video, the audio and video will start in sync but after about 30-45 seconds the audio will not be ahead of the video pretty noticeably. I checked the forums for previous posts and made some adjustments to the HW acceleration and the display scaling, but nothing seems to help. I then connected my Apple TV 4K to the same TV- both are running on the same network and 5ghz band- and the videos play flawlessly. I am not sure if I am missing something in the configuration or if other people are seeing this issue. I created a pastebin in case there was something that could be helpful.
https://pastebin.com/rWNWmumr
Audio out of sync- FireTV stick 4K
spweem
Re: Audio out of sync- FireTV stick 4K
I have the same issue. most files out of sync quickly.
This started a few months ago, worked perfectly to that point.
firetv(box)->hdmi TV ->Digital audio out to soundbar.
Tried changes recommended in old posts, nothing works.
I can play the same file with vlc and no sync issues.
clocks
This has been an issue with MRMC and FTV devices for months now. I've been using Plex. Not sure if MRMC will ever fix this issue.
3.7.1 release is pending a few items.clocks wrote: 29 Nov 2018, 00:56 This has been an issue with MRMC and FTV devices for months now. I've been using Plex. Not sure if MRMC will ever fix this issue.
DaMacFunkin
Do we think MRMC will support HD audio pass through on the new stick?
