Does mrmc still handle hd audio files as multi pcm?
Selest
Is DTSHD and TRUEHD decoded as PCM? and is it basically an hd lossless pcm that is sent to the receiver since the receiver is not displaying the truehd/dts symbol?
Re: Does mrmc still handle hd audio files as multi pcm?
Correct, All tvOS apps can only send multichannel PCM.Selest wrote: 30 Oct 2018, 18:40 Is DTSHD and TRUEHD decoded as PCM? and is it basically an hd lossless pcm that is sent to the receiver since the receiver is not displaying the truehd/dts symbol?
DTSHD and TRUEHD are decoded and sent as multichannel PCM.
Selest
But is that PCM stream coming from ATV4K a lossless stream that is the same as the DTSHD or TRUEHD or is it a downgraded stream similar to Dolby digital. Will there be a difference in sound between that PCM stream and DTSHD/TRUEHD?davilla wrote: 30 Oct 2018, 20:21Correct, All tvOS apps can only send multichannel PCM.Selest wrote: 30 Oct 2018, 18:40 Is DTSHD and TRUEHD decoded as PCM? and is it basically an hd lossless pcm that is sent to the receiver since the receiver is not displaying the truehd/dts symbol?
our audio experts say there is no difference.Selest wrote: 01 Nov 2018, 17:19But is that PCM stream coming from ATV4K a lossless stream that is the same as the DTSHD or TRUEHD or is it a downgraded stream similar to Dolby digital. Will there be a difference in sound between that PCM stream and DTSHD/TRUEHD?davilla wrote: 30 Oct 2018, 20:21Correct, All tvOS apps can only send multichannel PCM.Selest wrote: 30 Oct 2018, 18:40 Is DTSHD and TRUEHD decoded as PCM? and is it basically an hd lossless pcm that is sent to the receiver since the receiver is not displaying the truehd/dts symbol?
Selest
davilla wrote: 01 Nov 2018, 23:14our audio experts say there is no difference.Selest wrote: 01 Nov 2018, 17:19But is that PCM stream coming from ATV4K a lossless stream that is the same as the DTSHD or TRUEHD or is it a downgraded stream similar to Dolby digital. Will there be a difference in sound between that PCM stream and DTSHD/TRUEHD?davilla wrote: 30 Oct 2018, 20:21
Excellent! thanks. Is there a section I can go to so I can find the exact settings I need to set for both mrmc and atv4k?
- Everbrave
Out of curiosity, how does infuse handles HD audio differently from MrMC if at all?
infuse can only play video media. It has no capability for music or pictures.
- Everbrave
What about HD-audio tracks in the videos?davilla wrote: 09 Nov 2018, 14:04 infuse can only play video media. It has no capability for music or pictures.
- timstephens24
Same method is used by both apps, the HD lossless track is decoded and sent as PCM.
- Everbrave
I doubted so but was asking myself why infuse needs to license DTS etc. and MrMC/Kodi not, or do they?timstephens24 wrote: 09 Nov 2018, 17:24 Same method is used by both apps, the HD lossless track is decoded and sent as PCM.
