I've made changes to the media server I use and although all the files are identical, and in the same directory structure etc they are no longer mounted on the shield so I'll need to add them to MrMC as a new source.
Is there any way to do this and avoid having to rescan/readd all the files and lose my progress, what's been watched etc?
Avoid rescanning/remember progress? [SOLVED]
Re: Avoid rescanning/remember progress? [SOLVED]
Link MrMC to trakt, push current library watched items and after you change the paths and rescan the new items into it you can pull watches status back from trakt
Quartermass
Ah.. not quite as elegant as I was hoping. However now I've found out what Trakt is, it sounds like something I want to get anyway.
Thanks!
Thanks!
