Configure Skin Targets
aerogems
I am wondering if it is possible to change the target for skin shortcuts. For example, I am using the Plex client, and would like to have it so when I select "TV Shows" it takes me directly to the listing of all TV shows instead of first having to select my Plex server. That is currently the only thing keeping me from purchasing MrMC.
Re: Configure Skin Targets
see what's going on in the current testflight
aerogems
So am I missing something or... I went to the pinned thread about the MrMC 3.7.0 testflight, followed the link to the beta for the Lite version to test for Android, and I end up getting 3.6.2.
Did you request access to the beta builds?
There is no lite beta versions, you have to own a full version to get access to the beta build or wait for us to release 3.7.0 at which time lite version will be released as well
aerogems
That would be it then. I want to test the lite build before purchasing so I can be sure it will do what I want. Guess I'll have to check back when 3.7.x is out.
