Hi guys need some help Atv4K vs Shield
Introduce yourself here
brammeijer
Post by brammeijer »
Hi, guys, I'm new into media players, 4k and HDR
I've spent about 2 days googling stuff about this and can't get any closer to what I should get or keep
I just picked up a shield tv and tried it out for some time now and all I read is issues about frame rate and HDR and that upscaling 1080p content is crappie
I don't really like the android tv os and now I have like 30 chrome tabs open with forums about atv4k or shield
kodi vs spmc vs mrmc and how all the settings should be
I really like apple stuff and its the same price even a little cheaper and I read that it upscales 1080p stuff better than most tv's
this is my tv https://www.tcl.eu/en/products/uhd-p64-43dp640
I don't own a mac only an iphone and an ipad
I just use netflix, youtube and twitch
I torrent 1080p stuff mostly because netflix is limited here but now that I have a 4k tv im downloading those remux and other 4k hdr torrents some are like 60gb
so what would be a better option for me apple tv 4k or keeping the shield?
Re: Hi guys need some help Atv4K vs Shield
Post by timstephens24 »
I have an ATV4K and Shield, and I use the ATV4K 98% of the time.
brammeijer
ye, i really think im going to return the shield and just get the apple tv should i get the 64gb or is 32 enough? i understand it doesnt have usb storage option?
what do you use as server just a pc and plex?
i never use itunes
32GB is enough, there's nothing that really gets stored on the ATV4K that makes you need more than that. I use a Synology NAS with Plex.
And no, there's no USB storage, you'd need another device (like my NAS or a computer or even a router) to store your files and stream it to the ATV4K.
brammeijer
sounds great
do you agree that the picture is better on the apple tv?
i did read that shield 7.0 fixed some of the issues but i cant really find anything about it
apple tv seems just easier just setup it up enable match content download MRMC and go
the shield is just settings upon settings and again settings in the apps them selfs
It upscales from 1080p to 4K a lot better than the Shield does, and there's no color space issues since it will automatically switch between them. The Shield does a conversion between the color spaces and no switching, but I couldn't notice a difference, so I can't really fault it there. Audio the Shield wins since it will passthrough Atmos and DTS:X but if you don't have an Atmos or DTS:X setup then it's not an issue. I have a 7.1.4 setup and still prefer the ATV4K, but I do play some movies on the Shield or just the UHD disc on my player.
brammeijer
i just use the build in tv speakers as i dont really have space for a receiver and speaker nor the money
does that mean the atv can still play all the files just like the shield?
i tried some of the files direct on the tv with usb and it said Audio not supported
brammeijer
i never got into speakers and stuff more of a headphone guy i didnt try the 3.5m jack on the shield controller yet but that could be nice for me
just all the issues with the shield the apple tv just seems the better option me
1080P torrents and some netflix and some of the 4k hdr rips
do you use airplay at al?
edit:
also google assistant doesnt work in my language and siri does so that helps i guess
brammeijer
last night i did some a quick compare
shield at 4k req2020 with 1080p content looks fine?
shield 1080p req709 1080p seems fine?
i cant see any difference between the tv upscaling or kodi/shield or its just me
at 1080p kodi it switched to 4k when i play something that resolution and when i start something HDR the HDR10 logo pops up on the TV
frame rate switching also works fine
shield update 7.0.2 btw
If you're happy with it that's all you need.
