Fire TV (3rd Gen) and HD audio passthrough
e6onum
I use MrMC on Fire TV (3rd Gen) and enabled audio passthrough in MrMC settings. All videos that have audio in DD, DD+ or DTS are working, but videos with DTS-HD I get no audio on my Denon X2200. Is it a Fire TV hardware limitation or do I miss some settings in MrMC?
Endosmok
Re: Fire TV (3rd Gen) and HD audio passthrough
I just purchased MrMC a couple of days ago and ran into the issue you described.
I was able to get audio through by unchecking the buttons that indicate your receiver is capable of DTS-HD. Not really a fix but audio does come through.
YonathanZ
Endosmok wrote: 21 Jun 2018, 01:04 I just purchased MrMC a couple of days ago and ran into the issue you described.
But then you’re getting Dolby digital plus instead of lossless audio. Is there a way to actually get lossless audio to passthrough?
