IPTV EPG
dogdiego
IPTV EPG
Post by dogdiego »
Hi guys, newbie here. As per title, just looking for some advice before I commit to buying.
Just looking for some info around using IPTV with the program. This is probably my lack of knowledge around IPTV as well but I'm trying to figure out whether I can get a full EPG and logo's when using an IPTV service?
Trying to make the setup as wife proof as possible. The Plex integration is great so this would be ideal if I could get this setup.
Re: IPTV EPG
It works, I use it daily... depends on having a good server that will point to a correct channel logo and you need to add separate url for epg xml
