5 requests, some of them minor:
SUPERBIF
Post by SUPERBIF »
Hi a couple of requests:
1. Is it possible to make it an option to use the customsiricontroller.xml keymaps in Plex For Kodi like you use it in normal MrMC? That would be an excellent addition.
2. In Plex For Kodi addon, would it be possible to go back to main Kodi when pressing back key instead of having to confirm you exit the addon?
3. Would it be possible to have Plex For Kodi addon as an home menu item like "Videos" etc. so it's easy to select from main menu in MrMC?
4. ActivateWindow(PVROSDChannels) in LiveTV.
When having the channellist in LiveTV and selecting a channel, the ActivateWindow(PVROSDChannels) doesn't automatically disappear after selecting a channel. Can you make it an option to have this possibility?
5. Would it be possible to add Netflix and YouTube as home menu items in MrMC, so you don't have to exit each time. It would make it more complete.
Re: 5 requests, some of them minor:
3) is easy, go into skin settings for home items, there is an entry for plex addon.
5) gets tricky, such linkage might not pass Apple/Amazon App review.
