Hi there,
I'm considering switching from cheap Android boxes w/ Kodi to running Apple TV 4K with MrMC. I have two questions regarding the product:
1) Is hardware decoding of h264 Hi10P profile supported? If not, is there enough processing power to decode such sources in software (speaking of 720p or 1080p video)?
2) Is it possible to do offline scraping with a tool like Ember Media Manager and let MrMC just use the results instead of it rescraping the information?
Thanks!
Questions before purchase
- timstephens24
Re: Questions before purchase
1. It doesn’t do hardware decoding of h264 hi10p (it’s not really in spec so there’s not much that’ll ever do it) but it plays them back perfectly.
2. Yup, for Emby there’s an option in Services to link your Emby account and it’ll pull everything from Emby instead of scraping everything through SMB/NFS/etc shares. It also has the same for Plex (Plex is also getting the “Plex for Kodi” add-on added to MrMC next release).
Edit: I was just waking up and read Ember as Emby. @amet got me covered, though
2. if you use a different software solution that creates NFO files, MrMC will read those when importing content into library
Boulder
Thank you for the answers, just what I wanted to hear
Regarding item 2, does MrMC only use the nfo files or will it use the folder.jpg etc. that EMM creates and that Kodi uses?
it will use same png/jpgs like Kodi does
