Quick question on compilation
StretchyFrog
Hi, first of all, the project is amazing, congratulations. Now, I'm going to build MrMC for the third time when 1.2 hits the github (it will, right?). So far no problems with little help provided in other topic (http://forum.mrmc.tv/viewtopic.php?f=6&t=134). My question is: do I need to build all the dependencies (1hr make, etc.) or is it enough to rebuild the project using xcode?
Re: Quick question on compilation
Of course it will hit github. Busy away from things and Apple surprised us with a really quick review and pop.
You absolutely need to build depends
But the good thing is they don't change that often. That said, 1.2 brings in libdsm and some other tweaks to depends so they need to get rebuilt.
StretchyFrog
edit: Never mind, apparently there's no point in sticking with XCode 7.1. I tried in 7.2 and it worked fine.
Hi, thanks for the answer. I've just tried to build 1.2 (repeating the successful procedure I used for 1.0 and 1.1) and the build fails
Any idea what could it be? Thanks.
you have to rebuild depends, looks like libdsm is missing
make -C tools/depends/target/libdsm
or something similar
