Lip Sync With Live TV
ams123
Post by ams123 »
I am seeing lip sync issues with MrMC on my Apple TV. It occurs with live TV, my PVR is Argus TV, but it varies between channels. I have a RPI2 attached to the same system, receiver and TV, and don't see the same lip sync problem with the same channel and program. I don't see any lip sync issues with mkv files from bluray.
I don't see the same settings to automatically correct lip sync like in Kodi, I do see the manual adjustment.
Is there something I am missing?
Re: Lip Sync With Live TV
what settings are missing ?
when you say 'lip sync issues', do you mean that audio in not in sync with video ? we call that a/v sync.
which version of MrMC ?
ams123
Post by ams123 »
MrMC V 1.1.0 for tvOS
On the RPI2 there is a setting for A/V sync I did not even need to be using that since I was not using sync to display
Video > Playback > A/V Sync > - A/V sync method
But maybe that is platform specific since it's not on Kodi for OSX.
Regardless I am seeing A/V Sync issues and I am looking for a good way to fix that.
Thanks,
Aaron
mrmc.log would be helpful to see but must wait for 1.2 release.
