Hi
I set the music library to random play using the button in the full screen controls. When I try to turn it off again it crashes MrMc. Very reproducible. The repeat play button does not seem to have this problem.
I have tried closing the app, using the app switcher/killer, but this has not resolved the issue.
Revel
Bug report TVos: crash on random button click
Revel42
Re: Bug report TVos: crash on random button click
Hi.
I just managed to get 'random' to turn off without crashing the app!
I used the random button in the sidebar menu and it worked!
This has also fixed the behaviour of the button in full screen mode. Wtf.
Revel
Revel
Revel42
Hi
More testing....
If you are using random play on the 'songs' list deselecting random crashes the app. Doesn't matter which button you use, side bar or full screen.
If you are playing from a single album the button works fine.
Revel
More testing....
Revel
Thanks, I'll look into it.
found, fixed... might not be in 1.2.0 as thats already with Apple.
thanks for letting us know
Revel42
Thanks to you too
