Remote Bug
xuiph1
Remote Bug
Post by xuiph1 »
Hi guys,
Suddenly the scrolling functionality is not working (i mean Slide down, right or left and hold rather than realeasing and you ll be Able to scroll fast on library and menus) im runing version 1.1.0 i think its a Mrmc issue or Bug because i have other apps that the fast scroll works fine included kodi alpha sideloaded.
I have hope that the new Update will fix this but the issue remained.
Any sugestions.
Keep the good work,
Thank you
Re: Remote Bug
touch the pad, hold for a sec then swipe in direction needed
xuiph1
Re: Remote Bug
Post by xuiph1 »
amet wrote:touch the pad, hold for a sec then swipe in direction needed
Thank you amet, sometimes it works and sometimes dont work very well. :) when i bought mrmc, on the first release, scrolling on menus and in library is easiest and faster, but thats ok, in general the remote is working better and more precise. ;)
Re: Remote Bug
wait until you see the next release, I think its even better :)
joshy123
Re: Remote Bug
Post by joshy123 »
Any chance you could add an option for kodis old scrolling movement? From any of their builds before january 10th it was one of the smoothest yet have upgraded to their latest build and mrmc 1.2 but missing the old way already
Re: Remote Bug
Default is old remote handling
