tvOS Testing 1.1.1 (151230.1847)
Please use this ONLY if you have downloaded 1.1.1 (151230.1847), version number can be seen in TestFlight app
changes since last version:
- [fixed] json crashing, kodi iOS remote, play video
- add Amber skin
- dd PM3HD
- Match Apple tvOS Standard (Siri remote), remote handling from 1.1.0 is still there. 1.1.0 is default for now... optionally disable remote swipes in osd, settings -> input devices
- add Universal Movie Scraper(metadata.universal), needs
- ability to access mrmc.log, enable webserver -> go to http://<appleTV.IP>:<port>
- fixed, hang when using play/pause when resuming
BanRay
Re: tvOS Testing 1.1.1 (151230.1847)
Post by BanRay »
First impression:
-Skins work perfectly. I really like Amber!
-Remote like tvOS works. However, I wouldn't mind that when I swipe 'hard' this would result in a 'fast' scroll (more lines scrolled).
-Still, when my Time Capsule (SMB) was inactive for several minutes and I click to watch a movie, this doesn't happen. I noticed two behaviors. Either nothing happens and I have to click again, or MrMC says that the item is no longer available and I have to dismiss this message and click to watch again... So still issues with waking up the Time Capsule.
-Minor: localization of new menu items (e.g. input device menu) not done yet.
BanRay
Post by BanRay »
Pressing play/pause when resume watching: works.
Post by timstephens24 »
-Amber skin is awesome except the MrMC logo in the top left corner is where info for music that's being played is shown. Should probably be moved down some
-Remote like tvOS is good, except I'd like to see touch not activating jumping 10 seconds/30 seconds/etc, but a press depending on the side you're touched (if possible). I slide my finger across the trackpad way too much and then the video jumps all over the place. I know the remote's a work in progress.
-PM3HD skin is still around? Ugly... But hey, support for another skin wooooo.
-No issues pausing/resuming at all.
Also playing around with the remote app, and haven't seen any problems. I did get a mute icon to show up, and had to use the volume up json API call to fix it...
Hansel
Post by Hansel »
I quite like Amber too, although the skin settings are greyed out in Appearance. Not sure if that's intentional?
Hansel wrote:I quite like Amber too, although the skin settings are greyed out in Appearance. Not sure if that's intentional?
In which skin? Works here ...
"Swipe hard"/"Flick" should scroll faster but only in lists, it is intentionally disabled in home,settings and full screen playback
Touch is the only way to go, either we use edge tap or swipe. We have added remote timeout, play with that a bit.. It will ignore the first touch/swipe after N seconds.
I can add option to completely disable swipes in OSD, that way only edge taps work... Would that help?
Hansel
Post by Hansel »
Amber:
Amber:
My bad, will check again
