Dreambox streaming
blub2k15
Dreambox streaming
Post by blub2k15 »
Hello
is it possible to stream tv shows to mrmc like it was possible before with xbmc?
tuxbox://myuser:[email protected]:80/web
2nd question
why fits the osd not on my screen? the time and date is cut off and on the left there is also something missing.
thanks
Re: Dreambox streaming
There is enigma2 Pvr addon for tuxbox
Cut off screen is due to your tv not displaying 1:1, either set the tv correctly or use screen calibration to adjust screen size to your tv
blub2k15
Post by blub2k15 »
hi how can I install the enigma2 Pvr addon for tuxbox on apple tv?
its there, I think its called "vuplus" ...
http://kodi.wiki/view/VUPlus for how to use
