Maybe because technically there is no "Ice Age 1". It would just be "Ice Age". Also try adding the year after it in brackets, like "Ice Age (xxxx)".
This is not a bug and has everything to do with how you name your file and the source for the metadata, the movie database.
bug in add to library
Re: bug in add to library
explain ? in detail how Kodi has it right ?BAG_Ass wrote:jabohn
May be
but i think Manualy - interface more need where don`t find then find something.
PS in KODI it is made right.
jabohn
Did you change the file name like I suggested? Don't call it "Ice Age 1".
jabohn
It's not a bug when the customer is doing something wrong.
There is no "Ice Age 1" if you look it up in the movie database. It's simply called Ice Age.
https://www.themoviedb.org/movie/425-ic ... anguage=en
MrMC is using the movie database to find the information. If your movie file name doesn't match anything in the movie database then it won't work. Try naming your movie file "Ice Age (2002)" and rescrape and see what happens.
