best that can be done is this -> https://support.apple.com/en-us/HT201856
we can only receive IR buttons that apple allows, arbitrary IR button reception does not have an API.
long tach press substitute
Re: long tach press substitute
keymap.xml is not used in tvOS(apple tv) application
one option we might bring in future is ability to select what some buttons will do in certain windows(full screen playback, home, ... etc) but its still under discussion to see how best to do it.
no need to, I said we are looking at what the best way is to achieve it
