Getting consistent timeout error when trying to add video sources via SMB
yjpecht
Post by yjpecht »
New user on the AppleTV4.
Trying to add video sources via SMB (connected seemingly to same workgroup where my media files are) but getting consistent timeout.
Any ideas?
The files are hosted on a Windows 8 PC which is located on same workgroup.
TheJmc
Re: Getting consistent timeout error when trying to add video sources via SMB
Post by TheJmc »
Try to add the source by manually typing the server IP address, login and password in "Add network location"
yjpecht
Post by yjpecht »
No luck. Still getting timeout.
TheJmc wrote:Try to add the source by manually typing the server IP address, login and password in "Add network location"
TheJmc
Post by TheJmc »
Tried to restart your SMB server?
yjpecht
Post by yjpecht »
I assume you mean the Windows 8 PC in this case? That would be the SMB server?
TheJmc
Post by TheJmc »
That's right.
Also, check that your firewall is not blocking the access from the Apple TV.
yjpecht
Post by yjpecht »
There is no special firewall beside the standard windows firewall and in any case, if the Pie can access SMB, the appletv should as well.
yjpecht
Post by yjpecht »
P.S. access via upnp works fine.
