Hello,
Each time I search for subtitle on Opensubtitle I'm asked for credential (OK for podnapisi). I then cancel the request and proceed to subtitle selection & download.
Is it the expected behaviour ?
Account request with Opensubtitle
TheJmc
Re: Account request with Opensubtitle
Yes, it's normal.
To get rid of the dialog box, you can create an account in their website and insert your credentials in MrMC.
Yes, in theory you can search without credentials but there could be some search/download limits.
create an account, its free and helps the free site
- loekf2
I registered both for podnapisi and Opensubtitle, but looks like you can only enter the credentials for your default service ? Podnapsi looks a bit outdated, I would recommend Opensubtitle instead. Searching and downloading works fine. I would also make the default subtitle font a noth smaller. I think it's now 28 pt, which is kind of huge.amet wrote:Yes, in theory you can search without credentials but there could be some search/download limits.
