iTunes file sharing issue
hsyhai
Post by hsyhai »
According to the documentation in README.ios - iTunes file sharing should be available on the MrMC app on the AppStore.
In that case (MrMC will be sandboxed like any other app) - all MrMC files are then located in the sandboxed "Documents" folder and can be easily accessed via iTunes file sharing.
However when I plug my phone into iTunes - I don't see an iTunes file share folder for MrMC. Is this a known issue, am I missing something? I would love to be able to use MrMC offline when I'm traveling...
EDIT: It seems that this pull request doesn't exist in the MrMC codebase- Adaptions for developing for XBMC on non-jailbroken devices
Thank you
hsyhai
Re: iTunes file sharing issue
Post by hsyhai »
If I create a pull request with this implemented is there a chance it would be merged? Or is there a reason this hasn't been implemented yet?
we can try, it has been put on backburner as initially apple was asking for more changes while in review... this was in version 1.x if I remember correctly
PR please :) At the time we tried it, we were under pressure to get the release out so we just took out the hammer.
hsyhai
Post by hsyhai »
Alright I'll take a crack at it...
hsyhai
Post by hsyhai »
I am having trouble getting it to build using xcode - however reading the code it seems that all that is necessary is adding
<key>UIFileSharingEnabled</key><string>YES</string>
to mrmc/xbmc/platform/darwin/ios/Info.plist.in, because you can already access the internal filesystem using the special:// url.
Can you try it - I would try it myself but I can't seem to get xcode to build MrMC (even using a clean repo and following the directions in README.ios)?
Thanks!
hsyhai
Post by hsyhai »
Ok so adding <key>UIFileSharingEnabled</key><string>YES</string> enables it - and you can access the files via special://home/../ - Although there are a couple things:
  • I don't think Apple allows file sharing when the app files themselves can be accessed via iTunes. We have to figure out how to hide the app folder.
  • The url is a hack - we have to add another URL to access these files.
  • Probably should add an option in the sources UI - for Local....
in CDarwinStorageProvider::GetLocalDrives
Add;
#if defined(TARGET_DARWIN_IOS) && !defined(TARGET_DARWIN_TVOS)
share.strPath = CDarwinUtils::GetOSAppRootFolder();
share.strName = "iTunes Sharing";
share.m_ignore = true;
localDrives.push_back(share);
#endif
GetOSAppRootFolder returns the path to NSDocumentDirectory.
This will then show up in source/browse. As Documents is not available under tvOS, the compiler define only allows it for pure iOS. TARGET_DARWIN_TVOS includes TARGET_DARWIN_IOS as it is based off iOS so you have to exclude it if you only want pure iOS.
Hiding the App files from iTunes is more difficult as we can only place them at that location on the iOS device. See CDarwinUtils::GetUserHomeDirectory, this sets where special://home points.
And before you ask :)
#if defined(TARGET_DARWIN_IOS) && defined(__x86_64__)
is a special setup for internal development.
Everbrave
Post by Everbrave »
As I have been redirected to this post :)
You suggest to modify CDarwinSorageProvider and rebuild for iOS?
Where to find CDarwinSorageProvider and what are the steps for the iOS only build?
EDIT:
How this build would be different from the Kodi iOS build?
In kodi iOS, there exists a home folder with a document that folder in it but no media can be found there (just checked)!
