Testing MrMC 3.3.0
Re: Testing MrMC 3.3.0
Post by timstephens24 »
amet wrote: 24 Nov 2017, 16:30 thanks, got it and I think its fixed now ... new TF will follow soon
:thumbsup:
davilla wrote: 24 Nov 2017, 14:43 ooooooo, display rate switching for appletv 4k is semi-working :) Now to get it into the right place.
The switching with 11.2b is awesome in the apps with the native player. I haven't turned on my NVIDIA Shield in a few weeks.
Post by cosmoxl »
timstephens24 wrote: 24 Nov 2017, 17:00
:thumbsup:
Is the switching done by the OS itself, not dependent upon apps to do it?
That's the way the new roku OS 8 is, and I really like it. I hope Nvidia move that direction as well.
cosmoxl wrote: 24 Nov 2017, 17:03 Is the switching done by the OS itself, not dependent upon apps to do it?
You need to turn it on in settings, and then apps that use the native player (i.e. iTunes Movies, Netflix, Hulu, Crunchyroll, etc) will switch automatically. For other apps, they can do it two ways: when the app is launched they can switch to whatever color space/refresh rate is needed for that app and then switching back when the app is closed or switching like the native player when videos are played like what MrMC will do.
For MrMC, two setting will need to be changed. Again, this is AppleTV 4K only.
1) In MrMC, Enable Settings->Video->Playback->Adjust Display Rate
2) Enabled frame matching in tvOS settings. If disabled in tvOS, Matching will be ignored in MrMC even if you have "Adjust Display Rate" enabled in MrMC.
If your HDTV does not support the requested rate, the requested refresh rate change will be ignored.
A few things that I have seen so far, requesting 25 fps gets 50 fps. Same for 30 fps, that gets 60 fps. Still exploring this result. We don't have exact control as in FireTV2 and Shield, it is more a request for a frame rate match. Asking for 23.976xxx does get 23.976xxx and I've verified this with CADisplayLink tracking the native cadence of the display hardware.
A few more regression tests to make sure nothing is borked for the AppleTV4 and we should be good to go :)
barong
Post by barong »
Great. Can’t wait
This is all I’m waiting for before pulling the trigger on the full version.
Thanks for all the hard work.
(20171125-b181361)
darwin: tvOS, add display rate switching
plex: fix trailers
Enjoy :)
Going from 4K HDR at 60Hz to SDR is working properly, but going from 4K HDR at 60Hz to 4K HDR at 24Hz isn't. It switches the refresh rate successfully but it goes to SDR and not HDR.
timstephens24 wrote: 25 Nov 2017, 14:58 Going from 4K HDR at 60Hz to SDR is working properly, but going from 4K HDR at 60Hz to 4K HDR at 24Hz isn't. It switches the refresh rate successfully but it goes to SDR and not HDR.
debuglog please and what are your tvOS settings regarding video and matching ?
Apple TV Settings:
Format: 4K HDR (60Hz)
Chroma: 4:2:0
Match Dynamic Range: On
Match Frame Rate: On
MrMC Setting:
Adjust Refresh Rate: Always
In the log: I played Aladdin (1080p SDR BluRay remux) first, and that successfully switches to SDR, then when I stop it switches back to HDR. Then I played Batman v Superman (4K HDR UHD remux) and that switches to SDR then back to HDR, but it should be in HDR.
https://pastebin.com/8wS2eWVy
MediaInfo for BvS:
General
Unique ID                                : 283501925765781638450209489464260810308 (0xD5487C1CA9F63C34B7FE8C1C92FBD644)
Complete name                            : Batman v Superman Dawn of Justice (2016) - 2160p HEVC HDR UHD Remux Atmos TrueHD 7.1.Extended.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 75.8 GiB
Duration                                 : 3 h 2 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 59.4 Mb/s
Movie name                               : Batman v Superman Dawn of Justice (2016)
Writing application                      : Lavf57.71.100
Writing library                          : Lavf57.71.100
ErrorDetectionType                       : Per level 1
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main [email protected]@High
Codec ID                                 : V_MPEGH/ISO/HEVC
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Title                                    : Batman v Superman Dawn of Justice (2016)
Writing library                          : ATEME Titan KFE 3.7.3 (4.7.3.1003)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Statistics Tags Issue                    : mkvmerge v17.0.0 ('Be Ur Friend') 64-bit 2017-11-18 00:28:04 / Lavf57.71.100
FromStats_BitRate                        : 54403477
FromStats_Duration                       : 03:02:33.900000000
FromStats_FrameCount                     : 262631
FromStats_StreamSize                     : 74491288437
Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Content Light Level              : 4000 cd/m2
Maximum Frame-Average Light Level        : 1000 cd/m2
Audio
Format                                   : TrueHD
Format profile                           : TrueHD+Atmos / TrueHD
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Maximum bit rate                         : 8 199 kb/s
Channel(s)                               : Object Based / 8 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                            :  / 48.0 kHz
Frame rate                               : 1 200.000 FPS (40 SPF)
Bit depth                                : 24 bits
Compression mode                         : Lossless
Language                                 : English
Default                                  : Yes
Forced                                   : No
FromStats_BitRate                        : 4966494
FromStats_Duration                       : 03:02:33.901000000
FromStats_FrameCount                     : 13144682
FromStats_StreamSize                     : 6800311456
Menu
00:00:00.000                             : :00:00:00.000
00:10:10.652                             : :00:10:10.652
00:27:00.661                             : :00:27:00.661
00:37:49.225                             : :00:37:49.225
00:46:54.520                             : :00:46:54.520
01:02:04.971                             : :01:02:04.971
01:14:10.613                             : :01:14:10.613
01:28:07.115                             : :01:28:07.115
01:41:46.642                             : :01:41:46.642
01:53:52.617                             : :01:53:52.617
02:02:58.079                             : :02:02:58.079
02:15:04.054                             : :02:15:04.054
02:27:55.075                             : :02:27:55.075
02:36:51.444                             : :02:36:51.444
02:48:28.348                             : :02:48:28.348
02:54:43.765                             : :02:54:43.765
I tried with MySQL, Plex, and Emby, and all reproduced the same.
