So I was glad to hear that same will be supported by MrMC as well. But the result is poor...
The image is much smoother with playback at 60Hz. I am using the AFTV 1 gen. and I am facing studdering, asynchronity and slow-motion effects in 24Hz although the AFTV is switching to 24Hz and my TV is well supportng this rate. I am not sure if this is a software issue or a hardware limitation.
Therefore my question is: is 24Hz running well on a 2nd gen AFTV? This might be a good reason for me to upgrade the AFTV HW
Thanks for feedback in advance
Holger
