Database migration
Huey11
Database migration
Post by Huey11 »
Hello, I share a Kodi 18.7 mysql database with MrMc latest version I presume on Apple 4 HD. As far as I know it previously was no problem. But now, when I want to start I get the start screen and message “Database migrationin progress - please wait”
I know this message from Kodi when new schema changes had occurred. As far as I know it is still 116.
The thing is that the migration does not seem to stop...
I rather not de-install and re-install, as I would need to apply all settings again. Or would it keep those and is this the best course of action?
Please advice, regards
Re: Database migration
You might try to pull debuglog using webui if you had it enabled before.
If you uninstall MrMC you will loose all UI settings, connecting to MySQL database would get you the library back.
Huey11
Post by Huey11 »
Ok, so I am the only one having this problem? It looks like it is messing up the database. Kodi can also not use it anymore... Weird.
Very difficult to say since there is no debuglog to look at :(
As you can see, we have no other reports of any issues with the database
