I have a question regarding the event server implementation. Is it working differently than the one of Kodi or is it somehow limited? When I have the "event server" option in Yatse ticked MrMC is not recognizing any button presses of the Yatse remote control. I even tried the Kore App, but there I am not even able to tick the "event server" option. On Kodi all is working fine.
The event server in MrMC is up an running:
When I check the network traffic with WireShark I can see that Yatse is sending out the packets. As example:18:27:05.152 T:6114013184 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:27:05.152 T:6114013184 NOTICE: UDP: Listening on port 9777
I also tried putting a yatse.xml keymap in the keymaps folder of my profile directory, but this also didn't worked.R1 up
<?xml version="1.0" encoding="UTF-8"?>
<keymap>
<global>
<remote>
<up>Down</up>
<down>Up</down>
</remote>
</global>
</keymap>TVOS: 13.4.5
MrMC: 3.9-6
Yatse: 10.2.5B2
Kore: 2.5.0
