hieyemtim
Post by hieyemtim » 18 Feb 2019, 23:02
hieyemtim wrote:
17 Feb 2019, 20:05
semperfixd wrote:
15 Feb 2019, 05:24
Can you guys please check out "Nature's fury Lossless Atmos" from here
https://we.tl/t-ILkyOtizIY
(Play this file on MrMC and then on Plex. You will see what I'm talking about.)
I'm having dropouts and mapping issues with it.
Edit: Most Atmos files demos/ movies are working fine however the one that I linked above and one other is definitely having mapping issues. It used to work fine on 3.7.9
With February 14th build I’m having this exact same problem with mapping issues on this file. It never worked for me. Also, If I play any atoms file I have video and audio stutter for the first 20 seconds of each file. It has improved over the last few builds. Now my receiver doesn’t go back and forth from stereo to atmos to stereo to atmos. Thanks so much for improving the code. You’re almost there. So close.
2019-02-17 release. Atmos is much better. Only cuts out once. So so close. This file still has mapping issues and plays the center channel audio in the rear after about 10 seconds. I still wish audio on atoms files didn’t cut out once during each file. It’s a loud clipping (click) noise so I still can’t use it as my main player quite yet but it’s so much better. I do notice that remux 4K videos studder for a moment at the beginning of the file and that is usually where the atoms files have a loud audio (click) for a moment. DTSX files work without any audio clipping but I still notice the video shudder at the beginning. Love the new interface. So clean and crisp! Thanks for working so hard on this. So so close!
semperfixd
Post by semperfixd » 19 Feb 2019, 05:38
hieyemtim wrote:
18 Feb 2019, 23:02
hieyemtim wrote:
17 Feb 2019, 20:05
semperfixd wrote:
15 Feb 2019, 05:24
The file is playing fine for me now. Weird.
hieyemtim
Post by hieyemtim » 19 Feb 2019, 05:54
semperfixd wrote:
19 Feb 2019, 05:38
hieyemtim wrote:
18 Feb 2019, 23:02
hieyemtim wrote:
17 Feb 2019, 20:05
Yeah I’ve tried everything. Must be the way my receiver processes it. Its definitely better but I still have problems.
semperfixd
Post by semperfixd » 19 Feb 2019, 10:09
hieyemtim wrote:
19 Feb 2019, 05:54
semperfixd wrote:
19 Feb 2019, 05:38
hieyemtim wrote:
18 Feb 2019, 23:02
Okay you're right. The issue appeared again with the file "Nature's Fury" but pressing the seek back button (10seconds) fixed it. The issue is still there.
Post by davilla » 19 Feb 2019, 14:03
3.7.9 did not have AppleTV4/4K atmos handling.
When talking about atmos, it is very important to also include platform as atmos handling is very, very different.
Also check with mediainfo, it not eac3/atmos, then AppleTV4/4K will not handle it.
hieyemtim
Post by hieyemtim » 19 Feb 2019, 15:23
19 Feb 2019, 14:03
Hi Davila. This is testing for google play so we are talking about the Nvidia Shield and the latest build for android tv
Post by koying » 23 Feb 2019, 10:26
RC1 incoming. If you see bugs/issues, now is the time...
Those already posted and still present, please recap and I'll review.
semperfixd
Post by semperfixd » 23 Feb 2019, 11:57
koying wrote:
23 Feb 2019, 10:26
I have pushed you a file called "NCOP-1 (for ordered chapters)".
The issue is that
> With MrMC it skips frames (visible and is shown in the codec info.
EDIT: Logs: https://privatebin.net/?688644ae65ded08 ... pu85UrfAA= )
>No issues on Kodi 18.1
> No issue on PC
So the frame skipping only happens on MrMC
Post by cosmoxl » 23 Feb 2019, 13:45
koying wrote:
23 Feb 2019, 10:26
I still see switching of frame rate a few seconds into the DVD rips even though the setting is on "start/stop" only. You should have been able to test this with the DVD rip I sent you.
Also, the setting for AMC surface "allow interlaced content" does not affect mpeg2 but does affect h264. In other words, Surface is still used on interlaced mpeg2 even though interlaced content is disabled for surface.
Rootax
Post by Rootax » 23 Feb 2019, 16:59
In mkv files, if I jump to next chapter, then the playback become very choppy.
I don't know if anyone already reported this. If not, I can submit a log file.
