Playing Dolby TrueHD and DTS-HD MA
JohnWB
I am interested in getting an Apple TV 4K but using MrMCis there a way to get it to play Dolby TrueHD and DTS-HD MA, also will it play x264 and x265 10 bit files also high 10 and AAC files.
Re: Playing Dolby TrueHD and DTS-HD MA
It will play them without issue but HD audio will be internally decoded and sent via multi-channel PCM. Passthrough of HD audio is not possible on the AppeTV4/4K until supported by Apple.JohnWB wrote: 17 Jan 2018, 12:48 I am interested in getting an Apple TV 4K but using MrMCis there a way to get it to play Dolby TrueHD and DTS-HD MA, also will it play x264 and x265 10 bit files also high 10 and AAC files.
JohnWB
Thanks for the quick reply.
Will the PCM output be Lossless like the original, or will it be as the normal Dolby and DTS signals and will is contain any Atmos signals etc
eh ? PCM is not a compression format. HD audio will be decoded into multichannel PCM, You pick how many channels to fit your audio system setup.
We can passthrough DD/DTS 5.1 but not any HD audio formats.
You can always get MrMC Lite and try it.
JohnWB
Thanks for that.
I noticed that there was a problem playing videos with HE-AAC audio, have you made any progress with this please, or will it never be possible.
I'd have to check on reports problems playing videos with HE-AAC audio, 1st I've heard of it. Where can I find a sample ?JohnWB wrote: 18 Jan 2018, 09:50 Thanks for that.
Just checked with reference sample, seems fine. If there is a problem, I need a sample.
JohnWB
I saw it in this pos,t but maybe I miss read what was said.
https://mrmc.tv/forum/viewtopic.php?f=1 ... 9&start=10
"Infuse can playback H265 but it has issues with HE-AAC audio codecs"JohnWB wrote: 18 Jan 2018, 18:17 I saw it in this pos,t but maybe I miss read what was said.
The screenshot with HE-AAC had video playback issues, not HE-AAC audio issues.
HE-AAC audio is not an issue with MrMC
JohnWB
Thanks for that Davilla, just what i was hoping to hear
